Hi All
The Attached Screen shot showing the Feature Commands options any user disable or Enable it, How to find out which user enable or disable Feature commands options list?
Hi All
download the audit module so icingaweb2 audits it:
27.09. 08:04
monitoring/command moreamazingnick Issued command objects/hosts with the following payload: {"attrs":{"enable_notifications":false},"host":"Test"}
