I have the following strange behavior:
I define a host group in the Director and fill it with apply (host.name = * XY *). The “Choices” preview displays hosts matching the selection.
After successfully deploying, no hostgroups are displayed in icingaweb2.
Same thing if define only on cmd under conf.d/groups.conf (groups.conf included in icinga2.conf).
My system data:
Icinga2 2.11.0-1
Icingaweb2 2.7.1
Director master
Hello everybody.
I can say after some tests that it is probably a problem of icingaweb2. Because the groups are available and work as intended. In Nagvis the groups are displayed and functional.
Hi.
The problem seems to be solved.
After a major upgrade of the versions to
icinga2: r2.11.2-1
icingaweb2: 2.7.3
director: 1.6.2
the host groups can also be seen in icingaweb2.
(By the way, the services were not visible, as I have stated).
Unfortunately, it took a while because I have no internet access at the customer, so I had to set up an offline apt-mirror on a USB disk. This content first had to be scanned for viruses and released before I could use it.
Unfortunately, the official Ubuntu Mirror has generated some virus alerts, so I had to try several mirrors (Netcologne has worked in the end). All this took a few weeks because the customer’s workflows take a few days.
