Hi Icinga Team,
my icinga installation is HA Master <=> Master with a number of satellites.
Icinga2 latest (version: 2.11.4-1)
I created a new host using the API and directed the request to a satellite icinga instance.
The curl request was initiated from a node in a zone that cannot reach the master directly, but it can reach the satellite.
Here is the curl request to the API:-
curl -k -s -u 'user-name:password' -H 'Accept: application/json' \
-X PUT 'https://satellite01.somedomain.net:5665/v1/objects/hosts/pgApiTest2FromSat.testdomain' \
-d '{ "templates": [ "K8S Kube Icinga" ], "attrs": { "address": "192.168.5.1", "check_command": "hostalive", "vars.os" : "Linux" }, "pretty": true }'
"results": [
"code": 200.0,
"status": "Object was created"
Successfull creation of the host!
But wait… The host never turns up in the Icingaweb2 UI?
Also, the IP address I gave it will fail the ‘hostalive’ check, This was intentional to see if I get an alert.
So after a successfull creation of a new host that should now be alerting, I see nothing in my Icingaweb2 UI, no node, no alerts?
As a final check to see if the node was really created I called for a list of hosts from the satellite node.
curl -k -u "username:password" https://https://satellite01.somedomain.net:5665/v1/objects/hosts?attrs=address
{"results":[
...OTHER HOSTS REMOVED FOR BREVITY..
{"attrs":{"address":"192.168.1.1"},"joins":{},"meta":{},"name":"pgApiTestFromSat.localdomain","type":"Host"}]}
So the host is being reported as present.
The status now is.
A new host has been created.
The new host is not reporting any errors (although its IP address is not reachable for the ‘hostalive’ check)
The new host does not appear anywhere on IcingaWeb2
A host exists in our Icinga monitoring system that does not appear or alert?
Icinga Web 2 Version 2.8.1
Git commit 233bd29e4104125b4e5ef631e8c16dde33dadd9a
PHP Version 7.3.11
Git commit date 2020-06-29
Can any explain why the host never really gets created although it is present in the API
Thank you
Peter
