Hi there,
I’m wondering if it is possible to hand over the object_id in an check command?
Or is it possible to access it without an SQL query?
Regards,
Basit
Hi there,
Regards,
Basit
the object_id only exists in the database context, not when a check is executed. Also, when the IDO feature is disabled, it doesn’t exist.
What’s the idea behind this question?
Hi Michael,
basically we wanted to remember on our middleware for which object a check command was executed and store the object_id locally in our database.
If it is not possible as you said we will use host name and service name instead
Regards,
Basit
yep, better go with host_name and service_name tuples. Your middleware might just store a calculated hash from it for instance, making this an “object id”.
Hi @dnsmichi,
that’s a nice idea. Thank you!
