Freebsd 12.1 && Icinga shows an error when trying to enable features by command line
icinga was build on a fresh installed machine as first application (build by /usr/ports and tryed also by packages on another fresh machine) with same result.
Not sure where to fix the code…
Any hints/ideas?
Workaround: Set symlinks manually
root@a2:~ # icinga2 feature enable api
critical/cli: Cannot enable feature ‘api’. Linking source ‘…/features-available/api.conf’ to target file ‘/usrlocal/etc/icinga2/features-enabled/api.conf’ failed with error code 13, “Permission denied”.
critical/cli: Cannot enable feature(s): api
root@a2:~ # which icinga2
/usr/local/sbin/icinga2
root@a2:~ # tcsh -x /usr/local/sbin/icinga2 feature enable api
ICINGA2_BIN=/usr/local/lib/icinga2/sbin/icinga2
ICINGA2_BIN=/usr/local/lib/icinga2/sbin/icinga2: Command not found.
if test xuname -s
= xLinux -a xfeature = xconsole
if: Expression Syntax.
then
then: Command not found.
root@a2:~ # ll /usr/local/lib/icinga2/sbin/icinga2
-rwxr-xr-x 1 root wheel 10768176 Jan 27 09:50 /usr/local/lib/icinga2/sbin/icinga2*
root@a2:~ # uname -s
FreeBSD
root@a2 ~]# /usr/local/sbin/icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.2-1)
Copyright © 2012-2020 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Unknown
Platform version: Unknown
Kernel: FreeBSD
Kernel version: 12.1-RELEASE
Architecture: amd64
Build information:
Compiler: Clang 8.0.1
Build host: a2
Application information:
General paths:
Config directory: /usr/local/etc/icinga2
Run directory: /var/run/icinga2
Old paths (deprecated):
Installation root: /usr/local
Sysconf directory: /usr/local/etc
Run directory (base): /var/run
Local state directory: /var
Internal paths:
Package data directory: /usr/local/share/icinga2
PID path: /var/run/icinga2/icinga2.pid
