My suspicion (hence the title):
Does the flapping mechanism recognize the WARNING state the check_icmp when the warning threshold for PL or RTA is surpassed, though there is no “real” state change on the host?
That would be fixed easily by just raising the warning threshold to the critical threshold.
Host states are mapped, 0/1 = UP, 2/3 = DOWN when returning from the plugin. Meaning to say, if the plugin exit status flaps between 1 and 2, you’ll have a lot of flapping start/stop involved here.
Coming from the other topic, I’m not sure why you’d want this type of notifications enabled for hosts … I would rather e.g. subscribe to the API event streams and “do something” with these events. On a second note, those notifications are also stored in the database, slowing down the table lookups.
Good to know! But it seems I have of an exit status flapping between 0 and 1, looking at the host history.
Sadly, it is not me who wants them but the service management responsible for the customer, as the customer also has a monitoring system in place, that sends these notifications.
Also good to know (for me at least). Will bring that point up and see if someone cares
Will also try what effects changing the WARNING threshold has.
