Hello Icinga2 community,
while I did setup Icinga Web2, I decided to use LDAP as backend, which is working perfectly (User and Groups and permissions). Now I decided to configure a single User with another Ressource, just as a fallback in case of a LDAP maintaintance or if problem occurs.
So what I did is:
htdigest -c /etc/icingaweb2/.icingawebdigest “Icinga Web 2” fallback_user
in /etc/httpd/conf.d/icingaweb2.conf added:
<Directory “/usr/share/icingaweb2/public”>
AuthType digest AuthName "Icinga Web 2" AuthDigestProvider file AuthUserFile /etc/icingaweb2/.icingawebdigest Require valid-user fallback_user
in /etc/icingaweb2/roles.ini added:
[fallback_user] users = "fallback_user" permissions = "*"
in /etc/icingaweb2/authentication.ini added:
[autologin] backend = external
Unfortunately still only the LDAP login works. At the IW2 I also can see the Ressources and Authentificaton and changing the order does not change anything either. Does somebody have a idea?
Version: IcingaWeb2-2.7
Many thanks in advance!
