Hello, everyone,
I have the problem that no events are triggered. I think something is wrong with the configuration.
I created my events normally via the director. However, this is not carried out at all.
When I view the event, then go to the preview and open
“plugin-event-command” I get the following error: “Failed to load icinga_command” plugin-event-command "
The event is also not carried out.
Can someone tell me where my mistake is?
- Director version (System - About): 1.8.1
- Icinga Web 2 version and modules (System - About):2.9.3
- Icinga 2 version (
icinga2 --version):r2.13.1-1 - Operating System and version: Ubuntu Server 20.4
- Webserver, PHP versions:Apache , PHP 7.4.3
