I am trying to setup icinga on Centos7 . I am getting in the setup to the point where the error message. “There is currently no icinga instance writing to the IDO. Make sure that a icinga instance is configured and able to write to the IDO”
When I check if the database is created
MariaDB [(none)]> show databases like ‘icinga’;
| Database (icinga) |
| icinga |
1 row in set (0.01 sec)
Another hint:
check with “icinga2 feature list” if the feature “ido-mysql” is enabled and there are the correct informations to access the database in /etc/icinga2/features-enabled/ido-mysql.conf
