I would like to install the Icinga2 PowerShell module as I have done on many servers.
But there are 2-3 that are extremely resistant.
This is a Windows 2016 Server Datacenter.
I use the following script to install the agent:
[Net.ServicePointManager]::SecurityProtocol = 'tls12, tls11';
$ProgressPreference = 'SilentlyContinue';
[string]$ScriptFile = 'C:\Users\Public\IcingaForWindows.ps1';
Invoke-WebRequest `
-UseBasicParsing `
-Uri 'https://packages.icinga.com/IcingaForWindows/IcingaForWindows.ps1' `
-OutFile $ScriptFile;
& $ScriptFile `
-ModuleDirectory 'C:\Program Files\WindowsPowerShell\Modules\' `
-SkipWizard;
Remove-Item C:\Users\Public\IcingaForWindows.ps1
Use-Icinga;
Start-IcingaAgentInstallWizard `
-DirectorUrl 'http://IP/icingaweb2/director/' `
-SelfServiceAPIKey 'Key' `
-UseDirectorSelfService 1 `
-OverrideDirectorVars 0 `
-Reconfigure `
-RunInstaller
I get the following error there:
Use-Icinga;
-Reconfigure `
-RunInstaller
[Notice]: PowerShell Execution-Policies are configured to run Scripts and/or Modules.
[Notice]: Icinga PowerShell Framework is already installed. Using Framework functions for kickstarter.
[Notice]: Loading Icinga PowerShell Framework.
[Notice]: Using hostname "Servername" for the Icinga Agent configuration
Is your public Icinga 2 CA (ca.crt) available on a local, network or web share? (Y/n): n
[Notice]: The wizard is complete. These are the configured settings:
-AcceptConnections 1
-CAFile ''
-EmptyCA 1
-InstallFrameworkPlugins 0
-InstallFrameworkService 0
-RunInstaller
Start-IcingaAgentInstallWizard -UseDirectorSelfService 1 -DirectorUrl 'http://IP/icingaweb2/director/' -SelfServiceAPIKey 'Key' -OverrideDirectorVars 0 -AcceptConnections 1 -CAFile '' -E
mptyCA 1 -InstallFrameworkPlugins 0 -InstallFrameworkService 0 -RunInstaller
[Notice]: Found installed .NET Framework version 4.6.01586
[Notice]: Downloading Icinga 2 Agent installer "Icinga2-v2.13.3-x86_64.msi" into temp directory "C:\Users\SERVER~1\AppData\Local\Temp\Icinga2-v2.13.3-x86_64.msi"
[Notice]: Installing new Icinga Agent version into "C:\Program Files\ICINGA2"
[Error]: Failed to install Icinga 2 Agent:
[Notice]: A backup of your default configuration is not required. A backup was already made
It is not possible to call a method for an expression that has the NULL.
In C:\Program Files\WindowsPowerShell\Modules\icinga-powershell-framework\cache\framework_cache.psm1:7051 Zeichen:9
+ if ($ConfigContent.Contains('//const NodeName = "localhost"')) {
+ CategoryInfo : InvalidOperation: (:) [], RuntimeException
+ FullyQualifiedErrorId : InvokeMethodOnNull
[Notice]: Your hostname was successfully changed to "Servername"
[Warning]: No path specified for Framework service. Service will not be installed
[Notice]: Background daemon Cmdlet "Start-IcingaServiceCheckDaemon" has been configured
The Icinga Agent seems not to be installed
In C:\Program Files\WindowsPowerShell\Modules\icinga-powershell-framework\cache\framework_cache.psm1:4517 Zeichen:9
+ throw 'The Icinga Agent seems not to be installed';
+ CategoryInfo : OperationStopped: (The Icinga Agen...to be installed:String) [], RuntimeException
+ FullyQualifiedErrorId : The Icinga Agent seems not to be installed
Does anyone maybe have an idea what I can do to fix the error?
Thanks in advance
