Hello all,
I am having issues monitoring our Synology DSM NAS.
The plugin is installed while the services, check command and host is already defined.
But from the monitoring web interface, the error message below is returned
" No SNMP response received before timeout
Traceback (most recent call last):
File “/usr/lib/nagios/plugins/check_synology.py”, line 93, in
if disk.startswith(“No Such Instance”):
AttributeError: ‘NoneType’ object has no attribute ‘startswith’ ".
Please has anyone encountered this error before ?
Regards
