I am trying to somehow configure the authentication for a module, where we can store the user/password for each host and each customer in a separate file. I was trying to do something like this:
command.conf:
object CheckCommand "check_ilo" {
import "plugin-check-command"
command = [ PluginDir + "/check_ilo2_health.pl" ]
arguments = {
"-H" = "$address$"
"-u" = "$ilo_user$"
"-p" = "$ilo_passwd$"
"-3" = ""
"-d" = ""
include "/etc/icinga2/authfiles/$customer$/ilo.$address$.auth"
path to auth-file (example):
/etc/icinga2/authfiles/customer_1/ilo.192.168.1.45.auth
content of file:
vars.ilo_user = "administrator"
vars.ilo_passwd = "mypassword"
$customer$ is defined in Icinga Director as additional Field, $address$ is taken from the host config, also from Icinga Director.
If I use the absolute path, without any variables in the path string, it works. But then I need, in this case, for each ILO for all customers a new CheckCommand.
It would probably work, if I define user/password as additional fields in Icinga Director, but I don’t want this information in Icinga Director. To me it seems safer to have them on the Filesystem with restricted access (maybe I’m wrong).
Is there a way to solve this problem, or is my initial thought completely wrong? I could not find anything similar in this forum or internet.
Thanks,
Roman
