So i have attempted to produce a dummy service generator + dependency generator
I start out with this :
var klastry_backup["lubssbl03_full"] = {
nodes = [ "lubssbl01", "lubssbl02" ]
schedules = [ "sqlv2_sql99_full_week" ]
var klastry_backup["CHV09_WAWSDEVSQL"] = {
nodes = [ "lubshvh52", "lubshvh53" ]
schedules = [ "chv09_wawsdevsql" ]
and then i invoke a function that parses those structures and generates services with dummy check
wygeneruj_checki_tsm = function(klastry_backup) {
for (cluster => config in klastry_backup) {
for (schedule in config.schedules) {
log("making schedule " + schedule + " for " + cluster)
log("nodes are : " + string(config.nodes))
apply Service "tsm_schedule_" + cluster + "_" + schedule use(config,cluster,schedule) {
check_command = "dummy"
display_name = "Sprawdzenie " + schedule + " dla " + cluster + " " + string(config.nodes) + " " + schedule
vars.no_notifications = true
vars.no_notification = true
// this is a dummy host for those all services
assign where host.name == "tsmclusters"
var cluster_nodes = config.nodes
vars.dummy_text = datacenter.oblicz_avail_message(cluster_nodes, schedule)
vars.dummy_state = datacenter.oblicz_avail(cluster_nodes, schedule)
var nodes = config.nodes
} //schedule
} //namespace
datacenter.wygeneruj_checki_tsm(klastry_backup)
So far, it all works fine, but the calculation of dummy_text and dummy_state fails.
namespace datacenter {
//calculate how many nodes have a matching service with OK and return 0 if at least one is found
function oblicz_avail(nodes, schedule) {
// obliczenie stanu z nodow
var up_count = 0
var stan = 0
for (node in nodes) {
for (stan in get_services(node).filter(
(sv) use(node, schedule) => match("*" + schedule, sv.name)
).map(s => s.state)) {
if (stan == 0 ) { up_count += 1 }
} //for
if (up_count > 0 ) {
return 0
} else {
return 1
} // function
Function to gather status messages from discovered services
//gather status messages from matching services across the nodes.
function oblicz_avail_message(nodes, schedule) {
var message = ""
message += "checking for " + node + "\n"
for (mesg in get_services(node).filter((sv) use (schedule) => match("*" + schedule, sv.name)).map(s => s.host_name + " " + s.state + " " + s.last_check_result.output + "\n")) {
message += mesg
var up_count = 0
message += node + " " + schedule + " " + up_count + "\n"
return message
} // function
} // namespace
Now the odd thing is - in icinga2 the dummy status is always set to 1 ( which means the up_count is never altered from initial value of 0 )
And the dummy_text is generated from all lines that modify message EXCEPT the for loop.
e.g. i would get a message of ( in icingaweb2 )
checking for lubshvh52
lubshvh52 chv09_wawsiis07 0
checking for lubshvh53
lubshvh53 chv09_wawsiis07 0
While, if i declare neccesary variables in icinga2 console :
<2> => nodes = [ "lubshvh52", "lubshvh53" ]
null
<3> => schedule = "chv09_wawsiis07"
null
<4> => datacenter.oblicz_avail_message (nodes,schedule)
"checking for lubshvh52\nlubshvh52 2 [cappo71s] backup is Failed - The operation completed with at least one error message (except for error messages for skipped files). exit code 12, start date: 2022-12-26 19:00:00\nlubshvh52 chv09_wawsiis07 0\nchecking for lubshvh53\nlubshvh53 0 [cappo71s] backup is Completed - All operations completed successfully. exit code 0, start date: 2022-12-26 19:00:00\nlubshvh53 chv09_wawsiis07 1\n"
So basically, there is plugin_output visible here, which doesn’t appear in icinga2. And the up_count is 1 this time around. So the function is finding the services this time around.
How can i proceed to debug this better? Or does anyone have a clue as to what is going on?
