I’m having an issue where I have a simple check_disk service defined on our hosts as follows:
apply Service "disk" {
check_command = "disk"
vars.disk_cfree = "8%"
vars.disk_wfree = "10%"
vars.disk_ereg_path = [ "/" ]
vars.disk_ignore_eregi_path = [ "/snap.*", "/var/lib/docker.*" ]
command_endpoint = host.vars.agent_endpoint
assign where host.address
When I run the check_disk plugin directly on a host with these same options, it returns OK. However, in the Icinga web console, the check is permanently stuck in a Soft 1/3 CRITICAL state. However, if I use the “Check now” link in the web console, the check returns OK. Then the next time the check runs automatically, it goes back to the Soft 1/3 CRITICAL state.
Our main Icinga server is running version 2.12.0-1, and most if not all of our hosts are on 2.8.1-1. Icingaweb2 is on 2.8.2.
I’m at a loss for why this is happening, so any help is greatly appreciated.
