On a newly build IcingaWeb2 version 2.7.1 and Director 1.6.2, the first host I added to through director is not visible under Overview option.
I have read from - https://github.com/Icinga/icingaweb2-module-director/blob/master/doc/04-Getting-started.md#getting-started
When new to the Director please make your first steps with a naked Icinga environment. Director is not allowed to modify existing configuration in /etc/icinga2
. And while importing existing config is possible (happens for example automagically at kickstart time), it is a pretty advanced task you should not tackle at the early beginning.
How can this be fixed? Please help.
