HI there,
i just wanted to ask on how can i proceed with this one as im stuck on it.
hoping for a favorable response.
thanks in advance.
HI there,
thanks in advance.
did you check your kickstart.ini or your config in the UI in “infastructure” → “Kickstart assistent”?
this is what is shown in my UI.
i dont know how to continue and configure.
hoping for someone to help me,
what should i run first or do first, i think i ran into this but i hit a snag or didnt continue before since i’m not familiar
Kickstart can’t work if you don’t create the kickstart.ini or write the data into the UI
how to create the kickstart.ini?
As every other file under linux:
vim kickstart.ini
