Hi, I have an Icinga2 Installation with the latest Modules. In the Deployments, I have never ending cyrcles. Icinga Director ist up and running with some errors
● icinga-director.service - Icinga Director - Monitoring Configuration
Loaded: loaded (/etc/systemd/system/icinga-director.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-10-05 09:52:25 CEST; 16min ago
Docs: Introduction - Icinga Director
Main PID: 928 (icingacli)
Status: “running, db: connected”
Tasks: 1 (limit: 19115)
Memory: 28.1M
CGroup: /system.slice/icinga-director.service
└─928 icinga::director: running, db: connected
Oct 05 10:03:01 advsrmon122 icingadirector[928]: PHP Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:01 advsrmon122 icingadirector[928]: Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:06 advsrmon122 icingadirector[928]: PHP Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:06 advsrmon122 icingadirector[928]: Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:11 advsrmon122 icingadirector[928]: PHP Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:11 advsrmon122 icingadirector[928]: Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:16 advsrmon122 icingadirector[928]: PHP Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:16 advsrmon122 icingadirector[928]: Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:21 advsrmon122 icingadirector[928]: PHP Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
Oct 05 10:03:21 advsrmon122 icingadirector[928]: Deprecated: version_compare(): Passing null to parameter #1 ($version1) of type string is deprecated in /usr/share/icingaweb2/modules/director/library/Director/Core/CoreApi.php on line 50
PHP 8.1.11 (cli) (built: Sep 29 2022 22:28:49) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.11, Copyright (c) Zend Technologies
with Zend OPcache v8.1.11, Copyright (c), by Zend Technologies
Any Idea how to solve would be appreciated ?
