Director deloyment stucks
Hello, good mornig.
I have a Problem with Icinga Director Deployments. When I start the kickstart wizard on a fresly instaled icinga system and all services where imported into Icinga, I start to deploy the config and the deployment never stop. Also I do not have any active checks in the dashboard.
Does anybody have an Idea, how I can solve my Problem?
My System:
Distributor ID: Ubuntu
Description: Ubuntu 22.04.2 LTS
Release: 22.04
Codename: jammy
Icinga Web 2 2.11.4
Git Commit 11453bfa92a70a44efbf7f966f5e7f27e9300a28
PHP Version 8.2.3
MODULE VERSION
director 1.10.2
graphite 1.2.2
incubator 0.20.0
monitoring 2.11.4
Maybe there is an issue with PHP 8.2?
I got e.g . tis error messages in the icingacli:
icinga@icinga:~$ sudo icingacli --version
PHP Deprecated: Using ${var} in strings is deprecated, use {$var} instead in /usr/share/icingaweb2/application/clicommands/VersionCommand.php on line 50
PHP Deprecated: Using ${var} in strings is deprecated, use {$var} instead in /usr/share/icingaweb2/application/clicommands/VersionCommand.php on line 52
PHP Deprecated: Creation of dynamic property Icinga\Clicommands\VersionCommand::$trace is deprecated in /usr/share/php/Icinga/Cli/Command.php on line 61
PHP Deprecated: Creation of dynamic property Icinga\Application\Modules\Module::$configdir is deprecated in /usr/share/php/Icinga/Application/Modules/Module.php on line 264
Hello, good mornig.
My System:
Release: 22.04
Codename: jammy
Icinga Web 2 2.11.4
PHP Version 8.2.3
MODULE VERSION
director 1.10.2
graphite 1.2.2
incubator 0.20.0
monitoring 2.11.4
is the icinga-director service installed and running? this usually happens if the service is stopped.
but yes it seams that php 8.2 is not supported yet:
Upgrading to 1.10.x
Please check module dependencies, we raised some of them. In case you’re missing one of them, the Web UI will tell you after the upgrade. You’ll then be prompted to apply pending Database Migrations.
PHP 7.3 is now claimed to be required, but we still support 5.6+ on Director v1.10.x. Same goes for database dependencies: you should upgrade them to recent versions, but v1.10 still works on the ones supported with v1.9.x.
Yes the icinga-director service is installed an running.
icinga-director.service - Icinga Director - Monitoring Configuration
Loaded: loaded (/etc/systemd/system/icinga-director.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-03-13 18:09:42 UTC; 1 day 14h ago
Docs: Introduction - Icinga Director
Main PID: 2207797 (icingacli)
Status: “running, db: connected”
Tasks: 1 (limit: 9402)
Memory: 9.3M
CPU: 1min 48.549s
CGroup: /system.slice/icinga-director.service
└─2207797 “icinga::director: running, db: connected” “” “” “” “” “” “” “” “” “” “” “”
Mär 13 18:10:07 icinga icingadirector[2207797]: PHP Deprecated: Using ${var} in strings is deprecated, use {$var} inst>
Mär 13 18:10:07 icinga icingadirector[2207797]: Deprecated: Using ${var} in strings is deprecated, use {$var} instead i>
Thank you very much for your help. Will try to downgrade php. Do you know which php versions are working?
