We are having multiple node for the same service, is there a way to disable notification based on how many nodes left ?
I mean, we have 5 “web” nodes and will like to disable notification if we have 3 nodes running out of 5…
Create a business process (additional icingaweb modules required) and use the integrated icingacli command to setup your host/service check.
