I’ll hook into this, as I had the same problem just now (and sometimes in the past)
Log Master 01 (filtered for name of hosts)
[2020-02-19 09:10:22 +0100] information/Checkable: Checkable 'abc-0527-LR01' has 1 notification(s). Checking filters for type 'Problem', sends will be logged.
[2020-02-19 09:36:24 +0100] information/Checkable: Checkable 'abc-0527-LR01' has 1 notification(s). Checking filters for type 'Recovery', sends will be logged.
[2020-02-19 09:36:26 +0100] information/Checkable: Checkable 'abc-0527-FW01' has 1 notification(s). Checking filters for type 'Problem', sends will be logged.
[2020-02-19 09:36:26 +0100] information/Notification: Sending 'Problem' notification 'abc-0527-FW01!xy-0527-Hosts' for user 'xxx'
[2020-02-19 09:36:26 +0100] information/Notification: Completed sending 'Problem' notification 'abc-0527-FW01!xy-0527-Hosts' for checkable 'abc-0527-FW01' and user 'xxx' using command 'mail-host-notification-prio1'.
[2020-02-19 09:36:27 +0100] information/Notification: Sending reminder 'Problem' notification 'abc-0527-LR01!Ping_ISP_public_IP!xy-0527-Public-IP_ISP' for user 'xxx'
[2020-02-19 09:36:27 +0100] information/Notification: Completed sending 'Problem' notification 'abc-0527-LR01!Ping_ISP_public_IP!xy-0527-Public-IP_ISP' for checkable 'abc-0527-LR01!Ping_ISP_public_IP' and user 'xxx' using command 'mail-service-notification-prio2'.
[2020-02-19 09:36:27 +0100] information/Notification: Sending reminder 'Problem' notification 'abc-0527-SW-MS225!xy-0527-Hosts' for user 'xxx'
[2020-02-19 09:36:27 +0100] information/Notification: Completed sending 'Problem' notification 'abc-0527-SW-MS225!xy-0527-Hosts' for checkable 'abc-0527-SW-MS225' and user 'xxx' using command 'mail-host-notification-prio1'.
[2020-02-19 09:36:46 +0100] information/Checkable: Checkable 'abc-0527-SW-MS225' has 1 notification(s). Checking filters for type 'Recovery', sends will be logged.
[2020-02-19 09:37:44 +0100] information/Checkable: Checkable 'abc-0527-LR01!Ping_ISP_public_IP' has 1 notification(s). Checking filters for type 'Recovery', sends will be logged.
[2020-02-19 09:41:13 +0100] information/Checkable: Checkable 'abc-0527-FW01' has 1 notification(s). Checking filters for type 'Recovery', sends will be logged.
Log Master 02 (filtered for name of hosts)
[2020-02-19 09:25:26 +0100] information/Notification: Sending reminder 'Problem' notification 'abc-0527-LR01!xy-0527-Hosts' for user 'xxx'
[2020-02-19 09:25:26 +0100] information/Notification: Completed sending 'Problem' notification 'abc-0527-LR01!xy-0527-Hosts' for checkable 'abc-0527-LR01' and user 'xxx' using command 'mail-host-notification-prio1'.
Dependency-Configuration:
apply Dependency "abc-LR01_zu_abc-0527-Hosts" to Host {
parent_host = "abc-0527-LR01"
disable_checks = true
disable_notifications = true
ignore_soft_states = false
period = "24x7"
assign where match("abc-0527*", host.name) && host.name != "abc-0527-LR01"
states = [ Up ]
Notification apply rules (for hosts and service):
apply Notification "xy-0527-Hosts" to Host {
times = {
begin = 15m
command = "mail-host-notification-prio1"
interval = 0s
period = "24x7"
assign where match("abc-0527*", host.name) && host.name != "abc-0527-AP"
states = [ Down, Up ]
types = [ Custom, Problem, Recovery ]
users = [ "xxx" ]
apply Notification "xy-0527-Public-IP_ISP" to Service {
times = {
begin = 15m
command = "mail-service-notification-prio2"
interval = 0s
period = "24x7"
assign where service.name == "Ping_ISP_public_IP" && host.name == "abc-0527-LR01"
states = [ Critical, OK, Unknown, Warning ]
users = [ "xxx" ]
The user only gets the CRITICAL/DOWN notifications.
I have the feeling that times = { begin = 15m }
is the “bad boy” here.
Setup:
2 Masters, 2 Satellites (doing the checks)
CentOS7
Icinga v2.11.0 (trying to schedule an update this week to get to 2.11.2)
@ken Do you delay your notifications as well?
Another thought:
Host template:
template Host "_iamatemplate_" {
check_command = "icmp"
max_check_attempts = "3"
check_interval = 5m
retry_interval = 1m
Would it help raising the retry_interval for the parent host, e.g. to a multiple of the check_interval of the child hosts? That was a suggestion the last time I inquired about this. I can’t really see why that would help. Also this would delay notifications even further.
