what we did: made a mysql dump of the director db on a working master (A), and imported the dumb on a new master (B). Master B didn’t had any director configuration prior to this. Both systems work with director v 1.7.2.
Why we did this: goal was to import template structures and director settings from system A to system B. Without importing the host objects.
Question: How can host specific data from the dump be deleted within the sql table, while keeping the referential integrity? Since deleting them in the web-frontend will keep their data within the sql table.
Best regards,
Dave
