Using the current version of icingaweb2 2.95 and trying to figure out how to remove a dashlet. I cannot find anything in the documentation about adding or removing dashlets and the only topics I see on the forum regard re-ordering the dashlets but appear to be referring to an old version as the comments are a couple of years old
Hi Gary, regarding removing the dashlets, does /icingaweb2/dashboard/settings not work with the recycle bin at the right side?
Found it finally, the icon was so small I never noticed it. And not mentioned in the documentation that I can find. All is good now though, thanks for the response.
Gary
