Hi there
I am new to installing icinga2 for the first time. And hoping to install the icinga2 agent.
The “sudo icinga2 node wizard” command is failing for me. I am running the node wizard as root, and it still fails. Any ideas how to fix this?
# id
uid=0(root) gid=0(root) groups=0(root)
# ls -ld /var/lib/icinga2/certs/
drwxr-xr-x 2 icinga icinga 4096 Jan 10 05:01 /var/lib/icinga2/certs/
# icinga2 node wizard
Please specify if this is an agent/satellite setup ('n' installs a master setup) [Y/n]:
Starting the Agent/Satellite setup routine...
Please specify the common name (CN) [<hostname_hidden>]: <hostname_hidden>
Master/Satellite Common Name (CN from your master/satellite node): <hostname_hidden>
Do you want to establish a connection to the parent node from this node? [Y/n]: y
Please specify the master/satellite connection information:
Master/Satellite endpoint host (IP address or FQDN): <hostname_hidden>
Master/Satellite endpoint port [5665]:
Add more master/satellite endpoints? [y/N]: n
critical/cli: chown() failed with error code 1, "Operation not permitted"
critical/SSL: Error while opening private RSA key file '/var/lib/icinga2/certs//<hostname_hidden>.key': 33558541, "error:0200100D:system library:fopen:Permission denied"
critical/cli: Failed to create new self-signed certificate for CN '<hostname_hidden>'. Please try again.
