I already connected several clients/agents per agent script out of icinga director. Now I face the problem to integrate a NanoPI Neo. Ubuntu 16.07.04 Xenial that cannot (easily) be upgraded. Icinga is of version 2.4.1-1.
The agent setup script fails and I think I tracked it down to a TLS version mismatch.
The master says: [2022-01-25 16:40:48 +0100] critical/ApiListener: Client TLS handshake failed (from [10.10.7.231]:50852): unsupported protocol
TLS in general appears to be working: openssl s_client -connect principal:5665
seems ok.
I also found he parameter tls_protocolmin. But as i understand I can only set it to “1.2” which also is the default?
For my setup TLS/SSL is not really necessary as it is a home setup.
Any ideas how I can get the agent or running or is it more smart to do by_ssh checks?
I’m sure you know that your icinga version is quite old! As follow up of this maybe a problem is the cipher, which is harden since version 2.11 - Upgrading Icinga 2 - Icinga 2.
Yes, I know it is quite old.
The installation guide recommends using apt and repositories.
Unforntunately, the hardware is ARM based. The latest version I get through the repository the installed one.
Looking into the repository tree of xenial there is no armhf architecture or similar.
When I g**gle “install icinga2 from source” I do not get helpful results. All guides appear to you repositories.
