I am attempting to set up the director module and configuring from the icingaweb2 web UI. I navigated to Configuration / Modules / director and selected the Configuration tab.
My DB Resource is set to “icingaweb_db” and there is an error “Please change the encoding for the director database to utf8”
I have performed the following changes to the db and the utf-8 error persists.
— snip ----
MariaDB [(none)]> ALTER DATABASE director CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci;
Query OK, 1 row affected (0.005 sec)
MariaDB [(none)]> ALTER DATABASE icingaweb CHARACTER SET utf8mb4 COLLATE utf8mb4_unicode_ci;
Query OK, 1 row affected (0.001 sec)
— snip —
I am unclear, even after reading the docs, what to fill out in the Kickstart Wizard. I am not sure what the contents of the “Endpoint Name” field should be. The username and password I assume is defined in the /etc/icinga2/conf.d/api-users.conf file.
icingaweb is install on a centos 8 server
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: 2.13.2-1)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
System information:
Platform: CentOS Stream
Platform version: 8
Kernel: Linux
Kernel version: 4.18.0-365.el8.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 8.4.1
Build host: runner-hh8q3bz2-project-322-concurrent-0
OpenSSL version: OpenSSL 1.1.1k FIPS 25 Mar 2021
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
# ss -tnlp | grep 5665
LISTEN 0 128 *:5665 *:* users:(("icinga2",pid=3344,fd=22))
Icinga Web 2 Version
2.9.5
Git commit
053971c99dc1a4510beb64a888ea695cc14032dc
PHP Version
8.0.16
Git commit date
2021-11-18
# icinga2 daemon -C
[2022-02-23 22:30:52 -0500] information/cli: Icinga application loader (version: 2.13.2-1)
[2022-02-23 22:30:52 -0500] information/cli: Loading configuration file(s).
[2022-02-23 22:30:52 -0500] information/ConfigItem: Committing config item(s).
[2022-02-23 22:30:52 -0500] information/ApiListener: My API identity: icinga.acro.dev
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 GraphiteWriter.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 NotificationComponent.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 CheckerComponent.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 2 Users.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 UserGroup.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 3 ServiceGroups.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 3 TimePeriods.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 11 Services.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 3 Zones.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 4 NotificationCommands.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 2 HostGroups.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 24 Notifications.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 Downtime.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 IcingaApplication.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 Host.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 Endpoint.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 FileLogger.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 2 ApiUsers.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 244 CheckCommands.
[2022-02-23 22:30:52 -0500] information/ConfigItem: Instantiated 1 ApiListener.
[2022-02-23 22:30:52 -0500] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2022-02-23 22:30:52 -0500] information/cli: Finished validating the configuration file(s).
