Hello Everyone
I am relatevely new to Icinga2 and im trying to set up a Master/Satellite setup. I did my zones.conf and the api.conf. But i now have a message in my Logs of the Satellite node which looks suspicious.
information/IdoMysqlConnection: Last update by endpoint ‘UBUICI2’ was 7.70692s ago (< failover timeout of 30s). Retrying.
I have this message every 7.7s. To me it looks like a communicating issue between the master and the satellite but i really dont know where the problem is.
My Zones.conf on the satellite:
- Generated by Icinga 2 node setup commands
- on 2023-03-02 15:29:35 +0100
object Endpoint “UBUICI2” {
host = “192.168.XXX.XXX”
port = “5665”
object Zone “master” {
endpoints = [ “UBUICI2” ]
object Endpoint “ubuici3” {
object Zone “satellite” {
endpoints = [ “ubuici3” ]
parent = “master”
global = true
global = true
My api.conf
- The API listener is used for distributed monitoring setups.
object ApiListener “api” {
accept_config = true
accept_commands = true
bind_host = “Satellite_IP”
ticket_salt = “salt”
My Icinga version is: 2.13.6-1
Does someone have an idea why this is happening? If you need more informations please ask and i’ll provide them.
Best Regards xl3von
