Hi all,
trying to combine multipe variables in Director e.g. var.customer = “CustomerName”, vars.wmi_authfile_path = “/etc/icinga/auth/[ “$vars.Customer$” ].auth”
I defined vars.cusomers in Director Data List
object Service "CPU" {
host_name = "servername.domain.local"
check_command = "check_wmi"
max_check_attempts = "3"
check_interval = 1m
retry_interval = 30s
check_timeout = 30s
enable_notifications = true
enable_active_checks = true
enable_passive_checks = true
enable_event_handler = false
enable_flapping = true
enable_perfdata = true
command_endpoint = null
vars.Customer = "CustomerName"
vars.check_mode = "checkcpu"
vars.wmi_authfile_path = "/etc/icinga2/auth/[ \"$vars.Customer$\" ].auth"
vars.wmi_crit = "80%"
vars.wmi_warn = "60%"
How i can combine these variables that vars.wmi_authfile_path = “/etc/icinga2/auth/CustomerName.auth” will be the output at the end?
Director version 1.8.1
Icinga Web 2 2.9.5
PHP 8.0.14
