hi
I’m trying to implement cluster zone health check as per in the documentation.
I have 4 zones including the master zone, 3 up, 1 down, however, all zones are marked as “not connected”, even the master zone.
error message is in the topic title.
I tried to raise the warn/crit levels, no success.
The results from the agents are coming correctly from the zones, but the cluster-zone check seems fail.
how can I debug this?
also is there a way to debug the icinga2 built in checks in the ITL?
thanks
my Zone names are not equal to host.name.
also the checks seems good applied, as the correct zone names and queried
update: removed this variable, but no change
You should read this chapter especially the convention parts e.g.: " agent nodes also have their own unique zone. By convention you must use the FQDN for the zone name"
