Using the following configuration to check a cluster status:
template Service "cluster-check-tpl" {
import "generic-service"
check_command = "dummy"
vars.dummy_state = {{
var ok_count = 0
var warning_count = 0
var critical_count = 0
var unknown_count = 0
var service = macro("$service$")
var hosts = macro("$hosts$")
var num_hosts = len(hosts)
var critthreshhold = len(hosts) * 0.5
for (host in hosts) {
if (get_service(host, service).state == 0 ) {
ok_count += 1
} else if (get_service(host, service).state == 1) {
warning_count += 1
} else if (get_service(host, service).state == 2) {
critical_count += 1
} else if (get_service(host, service).state == 3) {
unknown_count += 1
} else if (get_service(host, service).last_check_result == null) {
unknown_count += 1
if (ok_count == num_hosts) { // OK if all childs are OK
return 0
} else if (critical_count + warning_count > critthreshhold || unknown_count > critthreshhold) { // CRITICAL if all childs are CRITICAL
return 2
} else if (unknown_count > 0) { // UNKNOWN if all childs are UNKNOWN
return 1
} else if ((warning_count + critical_count) > 0 ) { // WARNING if a problem exists on any child
return 1
vars.dummy_text = {{
var output = "Service " + service + " checked on " + num_hosts + " hosts:\n"
output += host + ": " + get_service(host, service).last_check_result.output + "\n"
return output
I get this (below) message when one of the 2 services is in an “unknown” state. It works well with “critical” and “ok” as it seems. I dont know what to make of it and if more info is needed i will happily provide it.
Exception occurred while checking 'ClusterChecks-ams1!haproxy-extern-ams1': Error: Closing $ not found in macro format string. (0) icinga2: icinga::MacroProcessor::InternalResolveMacros(icinga::String const&, std::vector<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> >, std::allocator<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> > > > const&, boost::intrusive_ptr<icinga::CheckResult> const&, icinga::String*, std::function<icinga::Value (icinga::Value const&)> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool, int) (+0xf32) [0x93d972] (1) icinga2: icinga::MacroProcessor::InternalResolveMacros(icinga::String const&, std::vector<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> >, std::allocator<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> > > > const&, boost::intrusive_ptr<icinga::CheckResult> const&, icinga::String*, std::function<icinga::Value (icinga::Value const&)> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool, int) (+0xbc0) [0x93d600] (2) icinga2: icinga::MacroProcessor::ResolveMacros(icinga::Value const&, std::vector<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> >, std::allocator<std::pair<icinga::String, boost::intrusive_ptr<icinga::Object> > > > const&, boost::intrusive_ptr<icinga::CheckResult> const&, icinga::String*, std::function<icinga::Value (icinga::Value const&)> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool, int) (+0x182) [0x93df12] (3) icinga2: icinga::DummyCheckTask::ScriptFunc(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool) (+0x335) [0xab0045] (4) icinga2: std::_Function_handler<icinga::Value (std::vector<icinga::Value, std::allocator<icinga::Value> > const&), std::enable_if<std::is_function<std::remove_pointer<void (*)(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool)>::type>::value&&(!std::is_same<void (*)(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool), icinga::Value (*)(std::vector<icinga::Value, std::allocator<icinga::Value> > const&)>::value), std::function<icinga::Value (std::vector<icinga::Value, std::allocator<icinga::Value> > const&)> >::type icinga::WrapFunction<void (*)(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool)>(void (*)(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool))::{lambda(std::vector<icinga::Value, std::allocator<icinga::Value> > const&)#1}>::_M_invoke(std::_Any_data const&, std::vector<icinga::Value, std::allocator<icinga::Value> > const&) (+0x1b4) [0x828524] (5) icinga2: icinga::Function::Invoke(std::vector<icinga::Value, std::allocator<icinga::Value> > const&) (+0x3f) [0xa07e4f] (6) icinga2: icinga::CheckCommand::Execute(boost::intrusive_ptr<icinga::Checkable> const&, boost::intrusive_ptr<icinga::CheckResult> const&, boost::intrusive_ptr<icinga::Dictionary> const&, bool) (+0x172) [0xa08002] (7) icinga2: icinga::Checkable::ExecuteCheck() (+0x298) [0xaaba08] (8) icinga2: icinga::CheckerComponent::ExecuteCheckHelper(boost::intrusive_ptr<icinga::Checkable> const&) (+0x32) [0xaac952] (9) icinga2: icinga::ThreadPool::WorkerThread::ThreadProc(icinga::ThreadPool::Queue&) (+0x77a) [0x8549ba] (10) libboost_thread-mt.so.1.53.0: <unknown function> (+0xd27a) [0x2b55cbdb127a] (11) libpthread.so.0: <unknown function> (+0x7dd5) [0x2b55cdcc5dd5] (12) libc.so.6: clone (+0x6d) [0x2b55cdfd7ead] (0) Resolving macros for string 'Service haproxy-http checked on 2 hosts: server1: Check haproxy OK - checked proxies: haproxy-http server2: Use of uninitialized value $haproxy in split at /usr/lib64/nagios/plugins/check_haproxy_stats.pl line 197. Unable to retrieve haproxy stats at /usr/lib64/nagios/plugins/check_haproxy_stats.pl line 199. ' (1) Resolving macros for string '$dummy_text$' (2) Executing check for object 'ClusterChecks-ams1!haproxy-extern-ams1'
