Checkeventlog quotes
I am using Icinga2.13.1-1 with IcingaWeb 2.9.3 and Director 1.8.1.
The check works from cli:
‘/usr/lib64/nagios/plugins/check_nscp_api’ ‘–password’ ‘’ ‘-H’ '10.’ ‘-a’ “filter=provider = ‘*’” ‘-a’ ‘scan-range=-1h’ ‘-q’ ‘check_eventlog’
check_eventlog OK: No entries found | ‘problem_count’=0;0;0
In Director I have configured it like this:
And in Icinga I get the following error:
The command that is trying to execute is:
How can I solve this single double quotes read error?
Thanks!
