Hi all,
Is it possible to use a CheckCommand on an Endpoint but have the EventCommand associated with that check run from the master and not the endpoint?
For example, I am using Salt to manage my infrastructure and whilst I am checking for services on the endpoints, the event command would be triggered through salt to restart a failed service as an example, however the Salt Master would most likely not be the endpoint being checked.
