I am using check_nwc for monitoring the CPU_Load of cisco network devices. The thresholds are set like Warning- 80% & Critical- 90%. But critical alerts are getting triggered even if the value is above 40%. Is there any solution for this?
on the service, select the inspect
link and see if the command being executed is the command (and arguments) you would expect.
I think inspect is only available if Icinga Director is enabled; if it’s not, you will need to look at the logs on the machine that executes the check (the master if you only have a single Icinga2 node).
Often times, a template or something steps over your changes, or the changes aren’t applied like you think they are.
