Check_logfiles Timeout exceeded
Hi everyone ,
I am using consollabs logfile plugin.
https://labs.consol.de/nagios/check_logfiles/#introduction
Sometimes it returns Unknown and says Timeout exceeded as you see in the ss below.
and in the agent process is hanging and consumes CPU too much.
I observed this situation a few days . I guess it happens only logfile’s gets so big .
If this is the issue ,what could be other solution other than making logfile iteration more often ?
Thanks !
I use https://github.com/Linuxfabrik/monitoring-plugins/tree/main/check-plugins/logfile and it work well with big logs and also allows to clear events by acknowledge them.
Or send the logs to a log server like Graylog and process them there.
Thank you rivad ,
You are trying to help everyone in this community .
Actually I was satisfied with the plugin I used except this issue . I will consider starting using the one you sent if I can not find other solution.
