vietdn
(duong ngoc viet)
1
I config icinga2 for check site status on localhost --> “intranet.skill20.net” with authentication basic “user:adam;password:Passw0rd$”.
List item I use: # curl -u adam:Passw0rd$ intranet.skill20.net
----> show content is OK.
–> is this complete ? help me!!!
stevie-sy
(Stevie Sy)
2
Could you show the service and command definition?
vietdn
(duong ngoc viet)
3
I modify file host.conf:
vim /etc/icinga2/conf.d/hosts.conf
can you help me config it.
fluxX
(Alex)
4
check the http command docs for available and correct parameters.
You looking for http_auth_pair
vars.http_vhosts["http"] = {
http_auth_pair = "username:password"
Looks like you are using the parameters for the apache-status check.
Can you show also the service definition as @stevie-sy already mentioned?
Greetz
fluxX
(Alex)
6
a full output from the error would help here a lot.
The actual error is not on the screenshot (just tested it myself to get the full error).
The password is ending with a $
sign. Icinga2 understands that as an opening macro - so try with the password Passw0rd$$
(note the double $
Greetz
vietdn
(duong ngoc viet)
7
wow. you are wonderful.
the password is ending with a $
(note the double $
and:
my password is Obligatory : Passw0rd$ ( ending with a $ sign). ---->So what should I fix? I read marco but dont understand. please !!!
dnsmichi
(Michael Friedrich)
8
please extract the full command line for this check. You can find the instructions in the troubleshooting docs.
vietdn
(duong ngoc viet)
9
If my password is: Passw0rd (not symbol $ ) —> is OK.
but I my password need " $ " behind string " Passw0rd$ " . so, how to do i do?
The docs say you need to mask it with another ‘$’, so you need to configure the password as ‘Passw0rd$$’
vietdn
(duong ngoc viet)
11
thank you very much !!! i love you . My problem is finish. i received help from every one. thank all !!!
