Hello
I have a problem with the connection between Icinga Host and Master. I get the following error messages:
[2024-11-21 11:55:00 +0100] information/ApiListener: Reconnecting to endpoint ‘m15084.fritz.box’ via host ‘192.168.20.139’ and port ‘5665’
[2024-11-21 11:55:00 +0100] warning/ApiListener: Unexpected certificate common name while connecting to endpoint ‘m15084.fritz.box’: got ‘m15084’
[2024-11-21 11:55:00 +0100] information/ApiListener: Finished reconnecting to endpoint ‘m15084.fritz.box’ via host ‘192.168.20.139’ and port ‘5665’
[2024-11-21 11:55:01 +0100] information/ApiListener: New client connection for identity ‘m15084’ from [::ffff:192.168.20.139]:52948 (certificate validation failed: code 18: self-signed certificate)
[2024-11-21 11:55:01 +0100] warning/ApiListener: No data received on new API connection from [::ffff:192.168.20.139]:52948 for identity ‘m15084’. Ensure that the remote endpoints are properly configured in a cluster setup.
I have an Icinga infrastructure that looks like this:
Icinga Master 01
Zones.conf
- Generated by Icinga 2 node setup commands
- on 2024-11-19 15:24:52 +0100
object Endpoint “icingamaster01.fritz.box” {
port = “5665”
object Zone “master” {
endpoints = [ “icingamaster01.fritz.box”, “icingamaster02.fritz.box” ]
object Endpoint “icingamaster02.fritz.box” {
host = “192.168.20.47”
port = “5665”
global = true
global = true
Icinga Master 02
Zones.conf
- on 2024-11-21 09:37:57 +0100
port = “5665”
global = true
global = true
Icinga DB Redis bzw. Redis Server
Icinga Databases Server
Icinga Web Server
