p0nt
(p0nts)
April 14, 2020, 2:27pm
1
I am receiving the following error after configuring the import source based on the official documentation.
This Import Source failed when last checked at 2020-04-14 15:31:56: AWS SDK not found (Class \Aws\Sdk not found)
I’ve unzipped the sdk zip file (https://github.com/aws/aws-sdk-php/releases/download/2.8.30/aws.zip ) into /usr/share/icingaweb2/modules/aws/library/vendor/aws but this does not solve the issue.
Anyone run into this issue aswell?
fluxX
(Alex)
April 15, 2020, 5:27am
2
i don’t use the module but in the installation instructions it says to use the “latest v3” version. Maybe it’s worth a try - download the latest v3 version from here 3.134.6 .
Greetz
p0nt
(p0nts)
April 15, 2020, 6:38am
3
Hi Alex,
Ah yeah, could be. I was following https://icinga.com/docs/director/latest/AWS/doc/01-Installation-and-Configuration/ which states to use v2 instead of v3 due to php version requirements.
It looks like it does more than it did with the v2 version, thanks!
p0nt
(p0nts)
April 17, 2020, 4:56pm
4
I hereby confirm this is the case
bsheqa
(Blerim Sheqa)
April 24, 2020, 10:19am
5
The correct docs are built now, sorry for the hassle!
