Hi Callum,
thank you for your quick answer.
I have already seen that thread and it does not help. The command suggested is
command: >
icinga2 node setup
--cn "{{ icinga_cn }}"
--endpoint "{{ icinga_master_host_cn }},{{ icinga_master_host }},{{ icinga_master_port }}"
--zone "{{ icinga_zone }}"
--parent_zone "{{ icinga_parent_zone }}"
--parent_host "{{ icinga_parent_endpoints.0.host }}"
--trustedcert "{{ icinga_certs_path }}/{{ icinga_master_host_cn }}.crt"
--accept-commands
--accept-config
--disable-confd
when: keypair_created is changed and save_cert is changed
This is icinga2 node setup I am looking to automate icinga node wizard
There is quite a bit of difference between these commands.
icinga2 node setup tried to fetch a signed cert from the parent icinga node
icinag2 node wizard does not as can be seen from a manual execution on an agent
icinga2 node wizard
Please specify if this is an agent/satellite setup (‘n’ installs a master setup) [Y/n]:
Starting the Agent/Satellite setup routine…
Please specify the common name (CN) [somenode.somedomain.net]:
Master/Satellite Common Name (CN from your master/satellite node): my-satellite-node.somedomain.net
Do you want to establish a connection to the parent node from this node? [Y/n]: n
Connection setup skipped. Please configure your parent node to
connect to this node by setting the ‘host’ attribute for the node Endpoint object.
Add more master/satellite endpoints? [y/N]: n
No connection to the parent node was specified.
Please copy the public CA certificate from your master/satellite
into ‘/var/lib/icinga2/certs//ca.crt’ before starting Icinga 2.
Bind Host []:
Bind Port []:
Accept config from parent node? [y/N]: y
Accept commands from parent node? [y/N]: y
Reconfiguring Icinga…
Disabling feature notification. Make sure to restart Icinga 2 for these changes to take effect.
Enabling feature api. Make sure to restart Icinga 2 for these changes to take effect.
Local zone name [somenode.somedomain.net]:
Parent zone name [master]: a-preconfigured-satellite-zone-name
Do you want to specify additional global zones? [y/N]:
Do you want to disable the inclusion of the conf.d directory [Y/n]:
Disabling the inclusion of the conf.d directory…
Done.
Once I have copied the ca.crt from the master and placed it in
/var/lib/icinga2/certs/ca.crt
icinga2 starts fine and when added to icingaweb2 it starts reporting status.
So I am looking for command line parameters for passing to icinga2 node wizard, then I will be able to automate the steps below.
Btw:
- icinga2 - The Icinga 2 network monitoring daemon (version: 2.11.3-1)
on all nodes.
Basically a brand new install of the latest and greatest.
Kind Regards
Peter G
