Hi there,
i just installed icinga2 on centos8 and tried to use our ldaps as auth-source.
the host itself uses ldaps, so there is no networkissue.
i tried the proxy-user and pw similiar to the systemwirde, but by testing the config, i get a connection-error. it seems, the icinga-ldap-client does not accept the ssl-cert provided by the ldaps-server.
i tried to add “TLS_REQCERT never” to /etc/ldap.conf even as its not, what one want to have, but it does not help anyway. where can i define the server-cert that should be accepted by icinga2?
i use (and have to use) ldaps not starttls
any hints?
regards
andreas
