I get this warning on one of the satellites.
I would like to get more insight into this warning. I ran “icinga2 daemon -C -x debug” but other than warning , I don’t see any other related details.
How do I debug the apply rule on a satellite ?
Please advise
ritzgu
July 23, 2022, 9:46am
3
@monigacom
Can you show us the service apply rule and maybe on of the host configs that it should apply to?
Here is the config info
apply Service "App2" {
import "generic-service"
check_command = "appcheck"
vars.user = "test"
if ( host.vars.tcp_ports ) { vars.portarg = true }
check_interval = 5m
assign where check_ifapp2host(host)
object Host "test_host" {
import "generic-linux-host"
address = "X.X.X.X"
vars.app = ["App2"]
vars.location = "DC"
I tried to use “debugger” on the satellite in the service config in /var/lib/icinga2/api… but it didn’t work while using 'icinga2 daemon -C -X"
So I’m not sure how to debug such problem at the satellite end.
ritzgu
August 5, 2022, 8:59pm
6
Does the function “check_ifapp2host” return true
for the host in question?
Yes , it does.
The issue turned out that one of the satellites was running a newer version of “icinga2” version. As soon as I downgraded it, the apply rule worked on it.
Still want to understand… how to troubleshoot such issue on a satellite though…
