Hi all,
we are currently running the following setup to set downtimes for terminal servers in an auto-scaling:
The Shutdown script on the agent host makes an API call to a HAProxy running on the satellite which is a hop to the master.
This was necessary as the agent hosts can’t reach the master directly and the downtimes are rejected if the satellite is used as endpoint for the API call.
Now we occasionally have the problem that downtimes “don’t turn up” even though the API call returns returns a success like ts1002!06ad14a8-5xaf-4fa8-a986-a012c09429bd' for object 'ts1002
but with no downtime being actually active
Example where at 22:32 the downtime was set via the script:
It seems to be in sync with config reloads.
The questions that I’m asking myself is:
May this be a bug that the API returns a successful downtime set and actually does nothing?
Can I, in some way, make this more robust?
Versions used on the master and satellites is 2.13.2
Cheers
