Hello everyone, after adding a second satellite, the check no longer works on the first satellite. please help me. We works whitout Director. Of course I used the node wizard to set up the second satellite. This also works. I have to add more satellites, what is the correct procedure? The first satellite do not sync the configuration like the second. Is there a problem whit the Certificate? Before I add the second the configuration was syncing.
My Configuration in File
out.txt (5.3 KB)
