I have followed all the below steps to get the Cisco-ASA, Cisco-nexus device under monitoring for check_nwc_health. But still am getting Error shown in the screenshot.
Installed Manubulon SNMP using below link : Install Manubulon SNMP plugins and Monitor a host with SNMP on ICINGA2 - AdminDocumentation
But still no luck. Please can you help me with flow in the director for adding device under monitoring.
Is monitoring allowed to talk to the device via SNMP?
Most common thing on our network when we have a timeout that’s not related to a real issue
Firewall ACLs – snmp needs to be allowed. You can test with a simple snmpwalk
from your Icinga node that is doing the checks (probably the master if you’re a small environment)
Hi Ben,
Thanks for your help. It was Network device issue, I did SNMP on both the devices but forgot to enable SNMP service on them. Its working now.
