O.Gracia
(Oliver)
1
I have a icingaweb2 with Director 1.8 and I have a little problem.
I add a command to monitoring a Dell Equallogic PS4000 and this command don’t admit arguments, i have this error:
critical/config: Error: Validation failed for object ‘check_equallogic.sh’ of type ‘CheckCommand’; Attribute ‘command’: Attribute ‘command’ must be an array if the ‘arguments’ attribute is set. Location: in [stage]/zones.d/icingaweb2.montornes.local/commands.conf: 52:5-52:50 [stage]/zones.d/icingaweb2.montornes.local/commands.conf(50): object CheckCommand “check_equallogic.sh” { [stage]/zones.d/icingaweb2.montornes.local/commands.conf(51): import “plugin-check-command” [stage]/zones.d/icingaweb2.montornes.local/commands.conf(52): command = PluginDir + “/./check_equallogic.sh” ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ [stage]/zones.d/icingaweb2.montornes.local/commands.conf(53): arguments += { [stage]/zones.d/icingaweb2.XXXXXXX.local/commands.conf(54): “-H” = { [2021-03-31 17:37:27 +0200] critical/config: 1 error [2021-03-31 17:37:27 +0200] critical/cli: Config validation failed. Re-run with ‘icinga2 daemon -C’ after fixing the config.
Can you help me?
Regards,
log1c
2
that’s not much information to go on.
Please show the command configuration.
cheers
O.Gracia
(Oliver)
3
HI,
This is command, Is my first Icinga configuration, I’m sure that i mistake something.
object CheckCommand "check_equallogic.sh" {
import "plugin-check-command"
command = PluginDir + "/./check_equallogic.sh"
arguments += {
"-C" = {
description = "Community"
order = 2
repeat_key = false
required = true
value = "$ARG2$"
"-H" = {
description = "hostname"
order = 1
repeat_key = false
required = true
value = "$host.name$"
"-t" = {
description = "Check type"
order = 3
repeat_key = false
required = true
skip_key = true
value = "$ARG1$"
vars["$ARG1$"] = [ "disk" ]
Thanks!!!
Regards,
Bins
4
Hello Oliver,
here is how our config looks like for the eql check
object CheckCommand "check_equallogic" {
command = [ PluginDir + "/check_equallogic.sh" ]
timeout = 1m
arguments += {
"-C" = {
description = "SNMP community"
value = "$snmp_community$"
"-H" = {
description = "DNS hostname or IP address of the Equallogic member"
value = "$address$"
"-c" = {
description = "Critical threshold"
value = "$equallogic_critical$"
"-t" = {
description = "Check Type"
value = "$equallogic_checktype$"
"-v" = {
description = "Volume name for single volume check"
value = "$equallogic_volume$"
"-w" = {
description = "Warning threshold"
value = "$equallogic_warning$"
Maybe it will help you to find your mistake.
Regards,
O.Gracia
(Oliver)
5
It’s working!!! Thanks!!!
