Acknowledge/Downtime from Master > Satellite doesn't work properly
Hi all! :slight_smile:
I’m using Icinga2 distributed with 1 Master and 2 Satellites with Top Down Config Sync method and I’m trying to figure out about behaviour of ack, downtimes, etc. from Master to Satellites replicate.
I have a master node with this configurations:
/etc/icinga2/zones.conf
object Endpoint "monitor1.XXXX" {
object Endpoint "monitor3.XXXX" {
        host = "monitor3.XXXX"
object Endpoint "monitor2.XXXX" {
        host = "monitor2.XXXX"
object Zone "master" {
        endpoints = [ "monitor1.XXXX" ]
object Zone "satelite" {
        endpoints = [ "monitor2.XXXX", "monitor3.XXXX" ]
        parent = "master"
        global = true
        global = true
/etc/icinga2/features-enabled/api.conf
object ApiListener "api" {
  bind_host = "0.0.0.0"
  bind_port = 5665
  accept_config = true
  accept_commands = true
  ticket_salt = TicketSalt
And all the configuration for hosts inside /etc/icinga2/zones.d/satelite/hosts and services inside /etc/icinga2/zones.d/global-templates.
Now satellites configs:
monitor2.XXXX /etc/icinga2/features-enabled/api.conf
monitor2.XXXX /etc/icinga2/zones.conf
        host = "monitor1.XXXX"
/*object Endpoint "monitor3.XXXX" {
        host="monitor3.XXXX"
        endpoints = [ "monitor2.XXXX" ]
        parent = "master"
        global = true
        global = true
monitor3.XXXX /etc/icinga2/features-enabled/api.conf
monitor3.XXXX /etc/icinga2/zones.conf
/*object Endpoint "monitor2.XXXX" {
        host="monitor2.XXXX"
        endpoints = [ "monitor3.XXXX" ]
        parent = "master"
        global = true
        global = true
All the new configuration made in master, I mean, changes/add/remove host/services are replicated perfectly to satellites, but something wrong happens when I tried to set, for example, an acknowledge for a service in Master (monitor1), it replicates sometimes well to one satellite (monitor2) but the other satellite (monitor3) never receive that configuration of ack. Sometimes on the contrary, monitor3 receive the ack from master but monitor2 no, what’s the problem?
Thanks in advance! :slight_smile:
  • Version used (icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1))
  • Operating System and version: All hosts are Ubuntu 22.04.3 LTS (Jammy Jellyfish)
  • Enabled features (Monitor1: api checker command ido-mysql mainlog notification, Monitor2:api checker command debuglog ido-mysql mainlog,Monitor3:api checker command ido-mysql mainlog)
  • Icinga Web 2 version and modules: version 2.12.1 with PHP 8.1.2-1ubuntu2.14
  • Icinga Web 2 modules:
director 		1.10.2
doc 		2.12.1
incubator 		0.20.0
migrate 		2.12.1
monitoring 		2.12.1
translation 		2.12.1
